dhcp-server-policy <DHCP-SERVER-POLICY-NAME>
<DHCP-POLICY-NAME> |
Specify the DHCP server policy name. If the policy does not exist, it is created. |
nx9500-6C8809(config)#dhcp-server-policy test nx9500-6C8809(config-dhcp-policy-test)#? DHCP policy Mode commands: bootp BOOTP specific configuration dhcp-class Configure DHCP class (for address allocation using DHCP user-class options) dhcp-pool Configure DHCP server address pool dhcp-server Activating dhcp server based on criteria no Negate a command or set its defaults option Define DHCP server option ping Specify ping parameters used by DHCP Server clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-dhcp-policy-test)#
no |
Removes an existing DHCP server policy |
